Splitter selection
ESA1178
179
Sacramento, CA USA
Hello all..
What type/model of splitter do you recommend for a rooftop antenna?
My Tivo/TV dramatically loses channels when I use an RCA splitter that was sitting in a box for years.
I would be splitting to 2 TV's...
Thanks all!
Mark
Hello all..
Thanks all!
Mark
What's the coax length from the antenna to the splitter, and from the splitter to the TV(s) ?
From the antenna to the splitter is about 10' . And from the splitter to the TV;s is about 20' each
Question: What is the difference tween a 5MHz -1 GHz & 5MHz - 2.GHz splitter ?
Mark
Mark
For that short of a distance, a Rocketfish 2 or 3-way splitter from Best But would work. That's what I use.
So not trying to flog a dead horse. And I know the graphic here is very simple:
Can I install a Power Pass Splitter? Coaxial #1 from Mast Amplifier to Power Pass IN on splitter. Coaxial #2 from OUT /Power Pass to Power Inserter. Power Inserter to Tivo Bolt/TV 1. Coaxial #3 from Power Pass OUT to TV 2.
Thanks again
Mark
The problem is probably either signal strength or a bad splitter.
Please post a TVFool.com report so we can assess the signal strengths you receive at your location.
A splitter is a simple device and most work about the same, expensive ones are not that much better than cheap ones.
The difference would only be noticed if your signal is near the digital cliff.
OTA now tops out at 692MHz and will soon collapse to 608MHz so chasing after a 2GHz splitter is not likely to bear any fruit.
I'd go with a splitter that only passes power through one leg rather than all legs.
KTFQ DT has added Charge!! Channel
Newest bandscan
