I have a VIP722 DVR-SD, software L512, Device: DPP Twin,Twin (1), Twin (2), Dual (3), Dishnetwork 1000 antenna with 3 LNB's.
I bought a 2nd (used) antenna on Ebay identical to the one I have that works on my current system so I could take it and my DVR on long camping trips. After a lot of failed attempts to get the newer antenna aimed properly, I finally mounted it on my roof near the one that works. When I remove the cables from the one that works and connect them to the newer antennna, the DVR won't find the satellites. The satellite finder I'm using indicates that the newer antenna is getting a stronger signal than the antenna that does work. But the on screen signal indicater, (when you go to menu>611) shows no signal. The connections are proper and functioning properly as evidenced by the fact I'm switching the same cable with 2 diplexers back and forth between the 2 antennas. When I connect the cable to the old antenna, everything works. Connect it to the one I just bought, the DVR can't find the satellites. This seems to be proof positive that the problem is with the newer antenna and/or the aiming of it. I'm convinced it's aimed properly because the satellite finder reports a stronger signal coming into the antenna that does not work than the one that does. So how do I check the LNB'S?
Thanks for the help,
Jim
