Here are the instruction I used exactly (I took notes every step of the way)
Remove the bottom panel first.There are 3 screws on each side behind the panel.Remove the panel and place on the floor directial in for on the tv.There are wires connecting the front panel controls and a/v connectors.I had about a foot of slack so it was no problem.This exposes 4 screws for the top panel.Now remove the top panel.There are screws along the top and sides and also the one you exposed when you removed the bottom panel.You need two people for the next procedure,Remove the front panel and hold in place in front of the TV.The person on the left must reach inside below and untie the twist wire connecting the autofocus sensors connected to the top inside panel.This will give you about 2 feet of slack.I had just enough slack to lay the front panel face down(lay a bed sheet on the floor)unscrew all 4 rail holding the paanels down. The rails have wires runnig along them,held down by plastic clips for the autofocus so just place the to the sides.Take out the 3 screen layers taped togetherand place on another bed sheet.Remove the black tape on the 4 sides of the panels and try your best to save the tape.Restack the protective screen to the back.Retape.Lay the new stack of screens in the frame.Put the rails back in place and screw them down(not too tight-don't strip),routing the wire around into the plastic clips.Put the screen frame back in place and replace enough screws to hold it in plac,I did on each side and one on the top.Now bring back the bottom panel and connect the a/v wires,but don't screw the panel in just yet.From here,you turn the set on and check out the picture and see how beatuiful it looks under different light conditions.I'm thankful I did this stepbecause I found that a wire was running down a corner of the picture,I had forgotten to put it in it's plastic clip.After it checks out finish replacing all the screws
Refocus and do convergence again
Here is the screen restack info,One thing I found though was I did not have two feet of slack and had to set the top panel on a table the height of the bottom panel in order to lay it down,also when removing the bottom panel after you get the screws out there are locking tabs still holding it in place,they act like the ones that hold car door panels in place,when you pop the loose it sounds like you broke something---Flashlight two people and take your time it isn't bad.I was also able to clean the inside on the set while i had it open ---Good Luck
