Hi y'all,
I'm new here, but it definitely seems to be the place to get a few questions answered. Basically, what I'm trying to do is upgrade my Mom's existing system to get her some DVR & dual tuner capabilities. I'll start with what she has now:
2 Dish 500 dishes, one with DP Twin LNBFs (for the 119 & 110 birds) and one with a DP(?) dual LNBF (for the 61.5 bird); one cable from each dish feeding each of 2 DP21 switches; the 2 output cables from the DP21s feeding a DP 322 receiver; the DP 322 feeding TV1 in the same room & TV2 in another room (with a UHF remote)
Here's what I want to end up with: a DP 522 feeding TV2 in single mode so she can watch & record different programs, etc. I'm planning to just leave the DP 322 feeding TV1 & just unplug the second outlet.
OK, so now for my questions:
1. If I replace the 2 - DP21s with a DP34, do I have to run both cables from the 119/110 dish into the inputs? I thought the DP Twin LNBFs had an internal switch so that both outputs had both satellites...
2. If the DP 322 is only feeding one TV, do I still need to run 2 cables to it to make it work properly? Or if I unplug the outlet to TV2, can I also disconnect one of the satellite input cables and use that cable instead as one of the two needed for the new DP 522?
Thanks for the help & sorry for being long-winded,
John
John
