I was wondering how well the slingbox works with directv. I had one with dish and it worked pretty well, but I didn't know if the directv receivers were supported. My current setup is the hr-34 and 3 clients. Thank!
Too bad the new remotes aren't backward compatible .
DVDDAD- how did you mirror your hr-34.. Does hdmi and component/ composite/s-vid all work at the same time?
If by "Ali havoc", you mean Slingbox, the Slingbox controls the source using IR. It is the one mode that is supported by almost all equipment.Just wondering, why does the Ali havoc require you to have the box in IR?
It is a DIRECTV "exclusive" to not support both remote modes simultaneously.
HR44 will support the old remotes IR only. The RF bands have changed in the new remotes, but the HR44 will do IR and RF at the same time.
So for a slingbox user this is a nice upgrade.
Really? Directv is the only company that doesn't have simultaneous IR/RF control for their equipment?
I have a Monoprice HDMI 1x4 splitter. One 8' HDMI to my main TV, one 50' HDMI to a 32" TV over my bar in the basement. Then I used two ioGear Wireless HDMI kits to send signals to 21" HDTV in my Kitchen and another 21" HDTV in my office. I don't use any component or composite (I don't think the HR34 has S-Video) but I do believe that all outputs are active on the HR34 all the time.
Obviously we're talking about those that feature both IR and RF.Theres still plenty of remotes that don't do RF for starters.
Perhaps you can cite an example to the contrary.Really? Directv is the only company that doesn't have simultaneous IR/RF control for their equipment?
This is an HDCP issue the only workaround is to either use component on the receiver to your TV, or get a powered HDMI splitter that fools the receiver in to thinking yrou TV is still on.I'm having an issue with my Slingbox Pro HD connected to my Directv HR24-500 with composite cable. For some reason, it will only sling the signal when the TV is on. Anyone have a fix? Thanks in advance.
