I have researched extensively the last couple of days on the subject of doing a slimline dish pole mount. I have found some good resources, but most of the info on these and other forums is older. So I just want to verify with others who may have had this done, or done it.
What I am looking to do is mount my slimline on a pole next to my garage. I just re-did my roof, and really do not like mounting my dish on the roof. I hate putting holes in my roof, and if the dishes were to change again in the future for any reason like when I went from my old triple lnb to the slimeline, the previous dishes mounting bracket and dimensions for the drilled holes do not fit, and you either need to leave the old bracket, or plug the old holes.
I know I need to use 2" galvanized steel pipe, and make sure it is thick as possible. I know I should bury the pipe 3 ft. in the ground and pour cement in the hole. I plan to run it next to my garage, so to get it over the roof, I need it to be 8-10 ft. above the ground. I plan on strapping the top of the pole to the garage under the eve trough. or to the side of it, making sure it is tightly held to the roof line for stabilization.
Does this sound like I am on the right track, or should I say screw it and mount it to the roof in the area I had it before. I would like to do the pole mount, because then I could move the dish to the back of the garage where it is less visible, instead of having it on the front where it is very visible from the road, as well as the reasons I stated above.
Thanks!
Thanks!
