Slimline Lnb
hoster
41
We just got the Slimline SL5S LNB and inserter and a 8 splitter.
Does anyone no where there is some install instructions for this setup?
All I can find is for the standard switch which ext and splitter.
I no it is simple but would like to see some info on different ways we can insall it.
Richard
The best way to install it is,
1. Run a Line with a ground Messenger from the Dish to a Ground Block that can be bonded to the homes electrical system.
2. Run a line to your in-Home lines
3. Plug in up to 8 Tuners (2 tuners taken up for DVR's) to teh 1x8 Splitter
4. Pick a location near a tuner to power the system
5. Make sure that location is on the Power pass port on the Splitter (Voltage meter or Cable Line Toner)
6. Get all of your Receivers ready minus the power.
7. Plug a jumper from your "Power" Receiver into the Power Inserter marked IRD
8. Plug the main Cable from the Power Pass Port into the Power Inserter marked LNB
9. Power up that 1 Receiver ad verify SWM settings are working.
10. Power up the rest if #9 checks out.
Hello
I got it figured out yesterday and have it working, but thanks for the good info.
I just had to take a good look at the parts and I got it to work.
Thanks,
Richard
