SKY MEXICO DALLAS/DUNCANVILLE AREA
Se necesita un dish de6ff kurdos band yo vivo en garland y tengo. Una de 1.2 y tngo. Signal. D 3. A 10 d la noche. Pero tengo. Amigos. Q compraron. La d la d 6ft y no tienen problemas con la signal
Bernal;3043051 Una de 1.2 y tngo. Signal. D 3. A 10 d la noche. [/QUOTE said:
Esto suena interesante!! Que LNB ku usas? que modelo "o" marca es? Que marca de antena tienes? Que Tp's "o" Frecuencias recibes y con que Calidad de Señal entre las 3 a 10 de la Noche?Que receptor usas?
A cuanto te baja la señal por la mañana?
Ya probaste con ajustar y fijar bien la antena y rotar el LNB?
This sounds interesting: What Model of LNB you are using? What is the brand of your antenna? What Tps you are receiving and what is the quality fo signal between 3- 10 pm? what receiver you are using?
What is the difference in quality signal in the mornings and evenings?
Did you tried to adjust very well your antenna and rotate your LNB?
Yo uso un LNB común y corriente en la casa de mis jefes que se suscribén al servicio eskay
Sent from my SPH-L900 using Tapatalk 2
Vallenato. Tengo una ku band. De 4ft tengo el receptor. Sky +hd los transponders mañana te los doy como me puedo comunicar. Contigo
There is a free 6 foot mesh BUD over in the C band section, thread: Craig's List Dishes.
It' somewhere in Texas. Yes, I know it's a big state.
And some junk collector probably got it for the scrap metal.
But maybe not. Would make interesting test with proper LNB & feedhorn. :)
FREE
edit: well, on reflection, a 6' mesh might not do Ku as well as a proper 1.2 solid.
I just got carried away in the spirit of the season. ;)
C band dishes
True fta Help
