Single remote tv --- how to get singals from two(2) DVRs
Racehorse
30
I've done it --- but it was new construction and the wiring is now covered over.
here is what I did ==== and proceeded to FORGET what I did ... <ggggg>
one DVR in living room sending TV2 signal out on channel 77 to remote tv in bedroom
one DVR in sun room sending TV2 signal out on channel 88 to remote tv in breakfast room
remote tv in kitchen receieves signal from BOTH DVRs via a single co-ax coming from the wall
==== I use TWO remote controls in the kitchen
---- if I want to watch the feed from the living room tv I use the remote control set to channel 77 output
---- if I want to watch the feed from the sun room tv I use the remote control set to channel 88 output
situation works FINE ... able to pick which feed with no difficulty by using the correct remote control
NOW ===
what did I do to achieve it ... I've forgotten how I coupled splitters/diplexers or what ever else and it is all covered over with drywall or flooring
I need help ..... <ggggg>
anyone got any idea how to wire this so I can do it for my daughter
horse
The attached diagram may help. However, it only shows one receiver. Repeat this setup for the second reciver. Next, join the 2 agile modulator feeds into a 2-way splitter (to what is normally the 2 outs) and connect the in with a short cable to the in of the 3-way (in your case) splitter, 4-way pictured in the diagram. With this setup all 3 TV2's--bedroom, breakfast room, and kitchen--will have access to all channels--77 and 88.
Hope this at least jogs your memory as to how you actually did your setup.
