New to the forums, I hope someone can shed some light on my problem.
I have had my HR21 HD DVR receiver since Wednesday last week. On Saturday, while recording one thing and watching another on Tuner 2, I kept getting lines and artifact in the picture and ultimately lost the picture and receiving a searching for satelitte error. It eventually came back. I checked the signal strength and noticed that on Sat 101, Transponder 1, Tuner 1 I get 95% Consistently. On the same Sat, Transponder, but Tuner 2 I get around 65% Consistently. Moving on to other Transponders and Sats, Tuner 1 & 2 are pretty close and in the high 80s and 90s, while on others I get a pretty large difference in the strengths. DirecTV tech support says that 60 or better for HD Receivers is OK and I shouldn't be concerned. Installer says that the receiver could be bad. I have tried to change the BBand between tuners with no change. I have also switched cables between tuners which caused an increase in the tuner2 signal from the 60s to the 80s, but transponder 5 on sat 101 dropped from 60s to the 40s. I haven't noticed any issues other than that Saturday a week ago. Is this something I need to worry about? Should the signal strengths not be the same on both tuners all the time? Thanks for any help that can be given.
