Hi Linuxman
it looks in picture that you are useing 72ohm coax (TV) it sud work better if you would use a 50ohm coax. I have used only 2-long wire antenns tru out my time, an they have worked ok, but not the best, comparied to a slopper or a die-pole for that freq. 1 that I had was about 180ft run between 2 towers, running north to south an then added another leg to it running east to west wich made it to a L, an total wire was about 280ft run, an the L worked the best, now on long wire didn't feed it with coax ran the wire right into my antenna tunner, it has a balun in it. now I have worked people that have made long wire's into a square, an they have came in with good signal.
Receiver Icom735 with 250khz an 500khz filters in it, yes a ham here.
remember that wire antenns receive in a donut fashion like if you have the wire going north to south, you will receiver signal better east to west, than a north to south signal.
