Sportsnet still workingok, thanks !!
But, if anyone in the Mesa area is currently (Oct 2023) getting Shaw it would be really helpful to know.
I am in Mesa, AZ and cannot find any sat. signal. I left Van., BC on Nov. 18, 23 and have not been able to receive any sat signal all the way down to Mesa. Howver, there are folks in this area that are receiving a strong signal. They have a 800 receiver with a 75E dish.ok, thanks !!
Is there some simple, approximating math that relates degrees of latitude to EIRP / dbW signal strength numbers?All of the test instruments require receiving a signal strong enough for the test instrument to detect.
This means you have to have a big enough antenna to amplify the signal to above detection level before you can do any testing.
Yes, satellites can have areas out of the published footprints where reception is possible. This is likely caused by manufacturing anomalies of the satellite antenna system.
Your report of someone in the area receiving with a bigger antenna - probably a 2.4 meter, indicates you might be able to do it. But, $$ gamble to find out if you can't find others in the area that are already doing it.
See my reply to nelson61 - if Denver is three degrees south of that central, latitude limit of G1, how far south of the west coast locale of Crescent City, Ca. would a signal be receivable with a larger dish...Denver isn't all that far from the boundary of reception of G1 -- maybe 200 miles. In the western US, the boundary runs just south of the 43rd parallel where Denver is near the 40th.
The fact that Denver is 400-500 miles further north than snowbird territory (33rd parallel) makes a huge difference.
The answer is no.Is there some simple, approximating math that relates degrees of latitude to EIRP / dbW signal strength numbers?
The signal maps are based on models and those models likely involve multidimensional calculus. Guestimating without the model would likely be impossible as the beams are not conical.Is there some simple, approximating math that relates degrees of latitude to EIRP / dbW signal strength numbers?
Years of experience have told me that EIRP maps are a good tool to use within the predicted coverage area.The signal maps are based on models and those models likely involve multidimensional calculus. Guestimating without the model would likely be impossible as the beams are not conical.
Hi. I'm assuming a larger dish would be needed, from 150cm to 240cm, but that's a hard thing to test when all you've got is 75cm. On the other hand, if you can get some kind of reading above the 'zero' floor, then at least it's worth investigating. I imagine finding a local technical facility who'd let you test with their large dishes is a possibility, but that won't be easy to find I'm thinking.Years of experience have told me that EIRP maps are a good tool to use within the predicted coverage area.
No matter where you are, it is always a good idea to build in some margin (1 or 2 dB or more) to reduce the number of hours per year that precipitation knocks out reception. All of this said, once you are outside of the
predicted outer contours provided by the service, it's a fool's errand to install something without first getting local confirmation of what actually works. This means getting some signal quality or dB readings at the location from an existing user that confirm reality, or physically go there in the absence of available local information and do an actual test yourself. There is nothing worse than an undersized dish to get an end user upset at the predicament they are in because somebody wanted to cut costs on the antenna size.
I imagine you're right. Ku band isn't all that popular since the advent of widespread broadband.I imagine finding a local technical facility who'd let you test with their large dishes is a possibility, but that won't be easy to find I'm thinking.
Does that help all that much with Ku?You would be more than doubling signal strength.
yes. In his case, he appears to be right on the edge of the receiver's signal/noise ratio for reception.Does that help all that much with Ku?
