SG9120B - only goes west
pacificrim
1,199
1,117
West Coast Canada
I put away a working SG9120B 2 years ago and today tested it. It only goes west, both by receiver or by the button. Pressing East results in a red light and a click - same as with the receiver.
I opened it up and applied 12v power to the motor board - correct polarity moved it east, reverse polarity moved it west successfully.
Any ideas?
Check for corrosion around the switching circuit and relays. Had a similar problem with a different motor a while back, had to re-solder some of the joints and I think I replaced some caps and a resistor or two... Some moisture had accumulated on the circuit board.
The Mystery Of The Disappearing NHK World Channel
lpb 87w ku
