I have replaced my KU setup with a SG9120B motor(42mm shaft) and a Geosat Pro 90CM dish. I have seen the threads that state the SG9120B manual is not correct and the the dish elevation should be 30-declination not 40-D.
Question: Does that mean the motor bracket settings in the manual are wrong too? Or are they correct and I just need to worry about the angle on the actual dish?
Thank you in advance.
