Great forum. I printed Iceberg's dual LNB mount postings and it helped the installer. Thanks!
Second professional installer came today with is BirDog (it's been a long month waiting on installers). I could tell he had not had experience with Glorystar specifically but seemed to have experience installing satellite systems in general.
So AMC 4 works great by itself direct. So does Galaxy 25. But AMC 4 will not work when both are connected.
Galaxy 25 works when plugged into the LNB1 port of the switch. But AMC 4 will not worked when plugged into port 2 of the switch. Swapped ports on the switch and AMC4 worked in port 1 but G25 did not work in port 2.
Installer thinks the switch is bad, which seems plausible. Are new switches sometimes bad?
I am also uncertain of is the settings of the set top box. There was lots of fumbling and trial and error with those. Does anyone have the exact settings to use for each satellite (LNB type, transponder, etc...)?
Thanks in advance!
Thanks in advance!
