Well, I got my Invacom QPH-031 today and of course, I have questions. I bought this LNB as my TS sat is Echo 7. My receiver is a Coolsat Pro. It appears as though I have to commit each sat separately to a port. On the Dish settings screen, which Diseqc setting do I use? I have a Coolsat switch. Which port on the switch should I use for the Echo and Direct TV sites and which for the others. Do I need to commit the cband sats to a particular port as I'm only using ku FTA? What is the uncommitted setting for? Are there any other changes I need to make with this LNB? I was told by someone that I need to set it as a "single" and not universal. Is this correct? What frequency should I use. Is the same frequemcy used for the circular sats (Echo, etc) as well as the regular sats? Will my Echo sats pick up a signal from both the linear and circular ports? Should I stick with just setting up the Echo sat at first and then set up the other sats? I know this is a ton of questions....Any help with the setup of this LNB would be greatly appreciated. Thanks!!!
