Set-up advise needed. Pl. help.
nirvina787
My set-up is as follows:
Dish 1: Dish 500 having two seperate DP Dual LNBF set for 119W and 110W. Both signals are received (strength 90 confirmed on DishPro 501 receiver).
Dish 2: Old 18" dish from directTV. Set for 61.5W. KU tupe single LNBF. Signal confirmed same receiver as above mentioned.
DiseqC Switch 1.2 (which came with receiver) is used to connect. Three single wire input goes and one output goes to one receiver.
Receiver: CS 5K Platinum. Firmware Loaded Bin 120.
My problem is at a time I can get only one signal. Either 61.5W from Dish 2 or one of the 119 or 110 from Dish 1. Dish settings are as follows:
119W
LNB Power: ON
Freq: 11.250
LNB Type: DishPro Twin LNBF
22 KHz: OFF
DiseqC switch: 1.0
Comitted: 1.0
Legacy: OFF
110W: Same as above except Comitted: 2.0
61.5: Same as above except LNB Type: Single, Comitted: 3.0
Pl. advise if this set-up is correct or not. If not, what I should do..?
Also, pl. advise on little things such as if the Power of the receiver should be 'Off' because out-put from the DiseqC switch is connected to receiver. Do I need to re-install Bin 120 again and start the set-up completely from scratch..?
Thanks in advacne.
boy that took some brains, huh?
Obviously at your IP, you must be posting from work. You must have tried really hard not to see the "WE ARE NOT A HACK SITE" warning when you registered 1/2 hour ago
so I'll say it slow.....for you
WE
ARE
NOT
A
HACK
SITE
So much like Kurt Cobain, "nirvina" (I know its Nirvana but its close) you are GONE
closed
banned
nuff said
Sr-fec Sid-vpid
That remote looks familiar
