Service Call in Cincinnati: A Tale of Woe
brazilplayer said:
Finally good news. The installer arrived at 11 AM (instead of the promised 9 AM) but this time he was prepared. Had read up on the installation..used the same strategy the TYORK suggested in this forum. Replaced the switch on the roof. Removed the new multiswitch that he had installed in the basement. Reattached one cable to each receiver and it all worked flawlessly after that. In all took under an hour.
Thank you all for your input. TYORK special thanks for getting me in touch with your boss.
I am still awed by the whole expereince. At some point, I would like to write a small note to Voom. Not to complain but to make them think of CS issues. They washed their hands off the service call from day 1. It was always "we have subcontracted that to someone else and it is not our problem anymore". Well, I think it should still be their problem. Furthermore, the guy who showed up was clueless for the first 2 days. Only on the 3rd day did he seem confident about what he was doing and did it quite well. Thus, what qualifies one to be a Voom installer. It seems apparent that he wasn't trained very well.
Finally, for those keeping scores. My daughter won the bet on the day of the install. I get to take her out for dinner today. I suppose I can count that as quality time with the kids.
ps. I had rather be watching the bearcats play finally!
you are more than welcome anytime glad i could help you and now you can watch the superbowl on VOOM . Hopefully you will be watching the COLTS.
just glad they got it working
Tyork
brazilplayer,
just to let you know, you are definatly not alone in your situation with prostardigital. I had a similar runin with them last month where they no showed on me 3 times for an initial installation in Columbus and voom basically washed their hands. They did give me a $25 credit for rescheduling. And if I remember correctly TVYORK offered his services and to call the regional manager for me.
Prostar could use quality people like TVYORK.
bucks17 said:
sorry tyork not t"v"york..... my hands get jumpy when I am typing.
No problem just glad i could be of some help to you guys.
Tyork
[VOOM] Re: Service Call in Cincinnati: A Tale of Woe
brazilplayer Wrote:
> A quick update on this saga:
> After I called TYORK's boss (thanks TYORK), the installer did show up
> at 4 PM. He found that there was just one cable going into the Voom
> receivers. I have 2 receivers. It seems there should have been two
> going into each That implies, as he said, I need a 2 new cables put
> in. I don't understand this stuff, apparently the Voom should have
> never worked with just 1 cable (his version). I know for a fact that
> Voom did work (both OTA and satellite part) through Christmas night.
> He wanted $60 for each line. At this point I am more than a bit upset.
> Either he does not know what he is doing or the initial Voom install
> was faulty. Either way I figure, I should not be charged for something
> I had paid for in May. So I call Tyork's boss again. I hate to bother
> the poor man. But he is the only one that seems to have the authority
> to make quick decisions and is quick professional about customer
> concerns. Bottom line, he told the installer to do what it takes to
> get this job done. The installer claims he needs some switch which he
> can only get in Columbus. He is going to come back today. That would
> be my 7 1/2 day of service call. Still counting...Keep you all
> updated. As I stated before everyone I know finds this hilarious but
> we are going to hang in for the ride. Superbowl Sunday still sounds
> like a possibility.
don't let him charge you for any switches cause they all are included
with your install if he tries call Jeff back. Hope you get to watch the
Super Bowl on VOOM I am guess it will be a go for you and you will win
this bet.
TYORK
This message was posted via http://www.satelliteguys.us by TYORK
brazilplayer Wrote:
> This has to be the longest running service call story..but believe it or
> not it still continues.
> The installer shows up at 1 PM. For those that have lost count, this
> is my 8th 1/2 day that is rescheduled from my real work. He lays down
> the 2 lines such that now 2 lines go to each receiver. He has to put a
> splitter switch (he calls it that), I don't know the technical term, in
> the basement. Puts on the receivers. Voila. No change.
> He now thinks that it is not the 2 wires that was an issue but maybe
> another switch up on the roof that combines the signals from the
> antenna and the dish. Therefore, he has to now run to Columbus (it is
> now 4 PM), and will be back at 9 AM in the morning. That would be the
> 9th 1/2 day rescheduled from real work for me.
> I know you guys are bored of this story but I am sure a part of you
> just wishes to see the final conclusion. The marketing prof. calls
> this sunk cost. You have to wait for the finale since you have waited
> this long. I am too numbed by the experience to vent at the poor tech.
> Oh well. I hope there is a grant finale tomorrow. Thanks TYORK for
> your optimism on the Superbowl deadline. I lost my bet today.
> Tomorrow's day was taken by daughter..and then my buddy at work has the
> day after that. The son has the days on and after the Superbowl Sunday.
brizalplayer,
My question is if there is a switch on your roof you should not have
another until you get to the receiver. Check the switch in the basement
see if it say splitter or diplexer if it say splitter there is the
problem. you should either have a diplexer behind you recevier or you
will have a grey box that snap on the back the combines the sat. and
antenna signal.
check and let me know.
TYORK
brazilplayer Wrote:
> Thanks guys. Here is what I had before the new line installs. 2
> Receivers with a grey box at the back. The one that seems to lock on.
> The installer tells me there is a switch on the roop that takes in 3
> cables and 2 come out down to the basement.
> Now in the basement he has a Wingard VM 3400 multiswitch. (I am not
> sure if it is a splitter or diplexer.
> The main problem is I can get local channels but not any channel over
> 100.
> What do I do now? It seems to me that if the to be replaced switch on
> the roof does not solve the problem tomorrow..the task may be way beyond
> the scope of the installer.
sound to me that you are hook up all wrong if you have 2 rec. and the
switch is in the basement than you should have 3 lines coming off your
roof and if you do no have 3 lines coming off you roof than you have a
diplexer on top . So what need to be done is the multi-switch in the
basement is kill your sat signal it need to be taking out and the line
need to be a straight line from the diplexer on the roof to the box .
TYORK
brazilplayer Wrote:
> Thanks Tyork. I guess the challenge will be to explain all this to the
> installer. Wish me luck for tomorrow. As much as I can see the humor
> in all this, it is starting to wear thin now.
well good luck , I sent you my cell number in you private messages so
if he has trouble when he get there give me call . i think it is
something simple to fix.
TYORK
brazilplayer Wrote:
> Thaks Tyork. I will keep you posted on what happends tomorrow and make
> actually take you up on your offer and have him call you. I wonder
> what happens to others though? Where do they turn for help?
well if they are in Jeff's area i try to help as much as possible or
they are several tech on here that are very helpful.
TYORK
Tyork
TYORK
brazilplayer,
bucks17
This message was posted via http://www.satelliteguys.us by bucks17
bucks17
Tyork
TYORK
B
RE: [VOOM] Facts and Speculation
M
[VOOM] Help AVS
