Server work tonight...
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,264
27,957
Newington, CT
I will be doing some work on our servers tonight, it appears we have a minor PHP problem and the way I am told to correct the issue is recompile PHP.
The server should NOT be down long. (fingers crossed) :D
Wish me luck! :D
Actually the thing he won't tell you is that the board is actually hosted on a Wii and he needs to take the game to a friends house!
Good luck. I have Concert tickets so you are on your own :)
LER
Ok work complete. :)
I didn't even need to take down the board for more then like 3 seconds.
Please let me know if you see any difference or problems. :)
There is no save password option (which actually saves a cookie to your PDA)
I need to add that in.
I had to switch from PDA to normal mode then login (and check the remember password box) then once I was logged in I switched back to the PDA mode with no more issues. :D
Guess whos working on the server again. :)
Should not be long (hopefully) and little to no downtime. :D
forum database server dun blow'd up
PDA edit mode problem
