separator vs. splitter
rjad
56
Separator and splitter look similiar, but I understand you can't use a splitter in place of a separator. But can one use a separator as a splitter to split out the VHF/UHF signals to serve two old TVs?
The separator is a specific piece of equipment to make the DishProPlus portion work correctly. If you try and use a splitter it wont work. Dish likes to use its own switches for obvious reasons :)
I don't understand the 2nd part....are you trying to combine a OTA antenna and the satellite cable into one? Thats a Diplexer
I understand the first part.
For the second part: I need to split the RF output from a receiver to serve two old TVs (barely used). Don't have a splitter handy, and there is an unused separater lying around. Can it be used as a splitter temperarily?
A seperator cannot be used as a splitter.
A seperator is kinda like a diplexor that seperates the "stacked" DBS band from the "normal" DBS band.
ah, ok...for that you can use any old RF splitter
A splitter will take one VHF/UHF signal path and divide it into two equal VHF/UHF signal paths.
A separator will take in one VHF/UHF signal path and separate it into one VHF path and one UHF path.
John
Local Channel Transponder Differ on 311 to my 522
Please help me find 129 AGAIN!
