Anyone with the Sathawk knows that setting the resolution to 1080i , also sets the composite output resolution to that illegal value, so the composite output doesn't work. You have to set the main Video res to 480i to get the composite output to work correctly.
Has anyone used a SCART adaptor on the Sathawk, and had any different results than I've described ? I'd like to use both composite out to a small TV (480i) and the hdmi at 1080i at the same time. Doesn't seem likely , unless the SCART method will work.
I know that the Azbox works fine on all outputs, but that rascal Iceberg talked me out of my Elite ! ( Okay, so maybe it was a little broke ! )
