Recently I purchased a Satwork 3688 and seem to have it down pretty good except for one thing, blind scan. I have it slaved through a Motorola 922. Can anyone tell me how to blind scan the horizontal and vertical seperate? It tells me it is scanning both, but when I am done all I have is horizontal FRs. Also about half way through the scan it will start over with the same begining FR that it started with.
This was a common problem with the 3618, but when you set it up for a blind scan, I set the 922 on a H or V TP and the 3618 would ask me what I wanted, H or V. All I had to do was match the 3618 to the 922 and I was in business.
The question is: is there a place on the 3688 that asks what polarity you want to scan? If there is, I am missing it.
Anybody that has any blind scanning tips for this reciever, pleeeeeeeese share them with me. I am getting desparate.
Update as of 11:40pm EDT
OK, I have been messing around with this blind scan for about an hour and this is what I came up with. It will scan X amount of signals on the H side, when it is done with H it will start the V side. It will then scan the same FRs and SRs on V as it did on H. Then when it goes to post the channels all of the H channels it found will be listed, then when it starts the V channels, which I said are the same FRs and SRs as H, it tells me "already searched" for all of the Verticals. So when the smoke clears the only channels that are stored are Horizontals. At first I didn't realize this, then I started scanning satellites that I KNOW have vertical channels, all I get is horizontals.
