SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 09/29/2007 - 51 changes
Uplink Comparison Range: 09/24/2007 08:40A - 09/26/2007 12:41P -
104 - SRI [MPEG2 SD] - EchoStar7 119W TP 11 ConUS beam changed to Available
284 - SETA (NA) removed from EchoStar8 110W TP 06 ConUS beam
285 - ESPND (NA) removed from EchoStar8 110W TP 05 ConUS beam
286 - REAL (NA) removed from EchoStar8 110W TP 05 ConUS beam
288 - SHO-E [MPEG2 SD] added to EchoStar7 119W TP 06 ConUS beam (Available)
289 - SHO-W [MPEG2 SD] added to EchoStar7 119W TP 08 ConUS beam (Available)
290 - SHOTO [MPEG2 SD] added to EchoStar7 119W TP 19 ConUS beam (Available)
291 - SHOCS [MPEG2 SD] added to EchoStar8 110W TP 21 ConUS beam (Available)
292 - SHOEX [MPEG2 SD] added to EchoStar7 119W TP 16 ConUS beam (Available)
293 - SBYND [MPEG2 SD] added to EchoStar8 110W TP 11 ConUS beam (Available)
294 - TMC-E [MPEG2 SD] added to EchoStar7 119W TP 10 ConUS beam (Available)
295 - TMCXE [MPEG2 SD] added to EchoStar7 119W TP 10 ConUS beam (Available)
296 - SUND [MPEG2 SD] added to EchoStar7 119W TP 12 ConUS beam (Available)
297 - FLIX [MPEG2 SD] added to EchoStar7 119W TP 17 ConUS beam (Available)
359 - CSNWS [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
360 - ALTUD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
374 - CSNMA [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
374 - CSNMA [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
375 - FOXOH [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
386 - FOXN moved from EchoStar5 129W TP 08 ConUS beam to EchoStar5 129W TP 27 ConUS beam (A)
544 - NHL [MPEG2 SD] - EchoStar7 119W TP 13 ConUS beam changed to Available
545 - NHL [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Available
546 - NHL [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Available
547 - NHL [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
548 - NHL [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
549 - NHL [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed to Available
550 - NHL [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
551 - NHL [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
552 - NHL [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed to Available
553 - NHL [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
554 - NHL [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Available
555 - NHL [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Available
556 - NHL [MPEG2 SD] - EchoStar7 119W TP 13 ConUS beam changed to Available
557 - NHL [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed to Available
558 - NHL [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Available
576 - ZEESA [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed to Available
576 - ZEESA [MPEG2 SD] - EchoStar3 61.5W TP 12 ConUS beam changed to Available
5992 - XKNXV [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5993 - XKPHO [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5994 - XKPNX [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5995 - XKSAZ [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5996 - XKTVK [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5997 - XKTVW [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5998 - XKTAZ [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5999 - XKFPH [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
7648 - KFBI [MPEG2 SD] added to EchoStar2 148W TP 18 ConUS beam (Not Available)
9421 - DSCHD renamed to HDTHR (A)
9443 - HDTV3 (A) removed from EchoStar3 61.5W TP 20 ConUS beam
9510 - VERIA (NA) removed from EchoStar8 110W TP 03 ConUS beam
9575 - VERIA [MPEG2 SD] added to EchoStar8 110W TP 03 ConUS beam (Not Available)
Transponder Changes:
EchoStar3 61.5W TP 20 ConUS beam 8PSK removed from tables
Channels in the system: 4460
(A) = Available to subscribers
(NA) = Not Available
