SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 08/18/2007
digiblur
14,190
4
Louisiana
Uplink Report Discussion - CLICK HERE
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 08/18/2007 - 19 changes
Uplink Comparison Range: 08/14/2007 11:46P - 08/15/2007 12:15A -
379 - CSNCH [MPEG4 HD] - EchoStar5 129W TP 27 ConUS beam changed to Available
805 - RTV [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed to Available
5759 - TWCTS (A) removed from EchoStar7 119W TP 06 ConUS beam
8918 - KRIS2 [MPEG2 SD] - EchoStar10 110W TP 27 Spotbeam 17 changed to Available
9468 - TESTB EchoStar5 129W TP 19 ConUS beam MPEG4 HD changed to VS/GF - Available
9468 - TESTB Echostar12 61.5W TP 19 ConUS beam MPEG4 HD changed to VS/GF - Available
9469 - INFO EchoStar5 129W TP 17 ConUS beam changed to MHD MPEG4 HD - EchoStar5 129W TP 19 ConUS beam - Available
9469 - INFO EchoStar3 61.5W TP 10 ConUS beam changed to MHD MPEG4 HD - Echostar12 61.5W TP 19 ConUS beam - Available
9487 - TESTC EchoStar5 129W TP 19 ConUS beam MPEG4 HD changed to DISC - Available
9487 - TESTC Echostar12 61.5W TP 19 ConUS beam MPEG4 HD changed to DISC - Available
9488 - TESTE EchoStar5 129W TP 19 ConUS beam MPEG4 HD changed to TLC - Available
9488 - TESTE Echostar12 61.5W TP 19 ConUS beam MPEG4 HD changed to TLC - Available
9489 - TESTF EchoStar5 129W TP 19 ConUS beam MPEG4 HD changed to ANIML - Available
9489 - TESTF Echostar12 61.5W TP 19 ConUS beam MPEG4 HD changed to ANIML - Available
9490 - TESTG EchoStar5 129W TP 19 ConUS beam MPEG4 HD changed to SCIEN - Available
9490 - TESTG Echostar12 61.5W TP 19 ConUS beam MPEG4 HD changed to SCIEN - Available
9492 - TESTA (NA) removed from EchoStar5 129W TP 19 ConUS beam
9492 - TESTA (NA) removed from Echostar12 61.5W TP 19 ConUS beam
Channels in the system: 4351
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 08/18/2007 - 23 changes
Uplink Comparison Range: 08/15/2007 12:15A - 08/16/2007 07:51A -
219 - DISH moved from EchoStar8 110W TP 10 ConUS beam to EchoStar8 110W TP 14 ConUS beam (A)
229 - DISH moved from EchoStar8 110W TP 14 ConUS beam to EchoStar8 110W TP 10 ConUS beam (A)
5955 - TST51 (NA) removed from Echostar12 61.5W TP 24 ConUS beam
5956 - TST52 (NA) removed from Echostar12 61.5W TP 24 ConUS beam
5957 - TST53 (NA) removed from Echostar12 61.5W TP 24 ConUS beam
5958 - TST54 (NA) removed from Echostar12 61.5W TP 24 ConUS beam
5959 - TST55 (NA) removed from Echostar12 61.5W TP 24 ConUS beam
5960 - TST56 (NA) removed from Echostar12 61.5W TP 24 ConUS beam
9472 - GLLRY moved from EchoStar5 129W TP 06 ConUS beam to EchoStar5 129W TP 22 ConUS beam and changed to MPEG4 HD (A)
9472 - GLLRY moved from Echostar12 61.5W TP 01 ConUS beam to Echostar12 61.5W TP 24 ConUS beam and changed to MPEG4 HD (A)
9476 - RUSH moved from EchoStar5 129W TP 06 ConUS beam to EchoStar5 129W TP 22 ConUS beam and changed to MPEG4 HD (A)
9476 - RUSH moved from Echostar12 61.5W TP 01 ConUS beam to Echostar12 61.5W TP 24 ConUS beam and changed to MPEG4 HD (A)
9478 - ULTRA moved from EchoStar5 129W TP 06 ConUS beam to EchoStar5 129W TP 22 ConUS beam and changed to MPEG4 HD (A)
9478 - ULTRA moved from Echostar12 61.5W TP 01 ConUS beam to Echostar12 61.5W TP 24 ConUS beam and changed to MPEG4 HD (A)
9479 - KNGFU EchoStar5 129W TP 22 ConUS beam changed from MPEG2 HD to MPEG4 HD (A)
9479 - KNGFU moved from Echostar12 61.5W TP 03 ConUS beam to Echostar12 61.5W TP 24 ConUS beam and changed to MPEG4 HD (A)
9482 - HDNWS EchoStar5 129W TP 22 ConUS beam changed from MPEG2 HD to MPEG4 HD (A)
9482 - HDNWS moved from Echostar12 61.5W TP 03 ConUS beam to Echostar12 61.5W TP 24 ConUS beam and changed to MPEG4 HD (A)
9485 - GAMEP EchoStar5 129W TP 22 ConUS beam changed from MPEG2 ViP to MPEG4 HD (A)
9485 - GAMEP moved from Echostar12 61.5W TP 03 ConUS beam to Echostar12 61.5W TP 24 ConUS beam and changed to MPEG4 HD (A)
Transponder Changes:
Echostar12 61.5W TP 01 ConUS beam 8PSK removed from tables
Echostar12 61.5W TP 03 ConUS beam 8PSK removed from tables
EchoStar5 129W TP 06 ConUS beam 8PSK removed from tables
Channels in the system: 4345
New PDF files
  • DishNet2007.08.16-ByChannel.pdf
  • DishNet2007.08.16-ByBeam.pdf
Ethernet port active on 622!!!
Add HD to any package for an additional $20/month?
