SatelliteGuys Special Offer
SatelliteAV
6,486
186
Roseville, CA
Blowout Pricing $ 325 any quantity
Lacuna Mark III Satellite Identification Meter
Suggested Retail $430
For more information visit LACUNA MARK 3 SAT IDENTIFICATION METER - SatelliteAV, LLC.
lacuna \luh-KYOO-nuh\, noun;
plural lacunae \luh-KYOO-nee\ or lacunas:
1. A blank space; a missing part; a gap.
Lacuna has listened to the thousands of professional satellite installers who own Lacuna products and made the best satellite meter even better! The New Lacuna Mark 3 meter will assist with making your satellite installs faster and more accurate, resulting in better income potential and less service calls!
New Features:
  • Extended Run time with a larger capacity battery
  • Operate the meter while charging
  • Powers up to last used satellite and transponder
  • LNBF test function
  • Six data groups to organize 120 satellites and thousands of transponder combinations
  • Easy navigation with new multi-button touch panel and streamlined menus
  • New 4 line LCD display features high and low signal level indicators with Quality (BER) reading
  • USB connection upgrade port for easy access and connection to a laptop (cable not included)
  • User adjustable Quality (BER) sensitivity settings
  • User adjustable auto-off timer
Standard Features:
  • Control 22KHz, DiSEqC, DP and Multi - switches
  • 120VAC wall charger
  • 12VDC accessory / cigarette lighter charger
  • Water resistant soft carrying case
  • Preloaded with the most current satellite and transponder lists
  • Easily upgrade to latest firmware and updated datasets
Easily update your meter with the latest satellite and transponder lists available at satmeter infosite - home
Identifies and peaks quality for the following standard applications:
  • Dish Network - All including DP Plus
  • DirecTV - All including AT-9
  • Starband
  • DirecWay
  • Free to Air
  • KA-Band
  • KU-Band
  • C-Band
  • Circular
  • Linear
  • Universal
  • Standard
  • Band Stacking
Absolutely the easiest meter to use!
I have one of these, and I finally got to use it to install my DirecTV dish a few weeks ago and it worked great. In fact my signal levels were as good if not better then someone whos a professional installing the dish.
If you check out my DirecTV diary I talk about this meter in there a bit.
I was VERY happy to have this meter and it made installing this difficult dish to install a breeze!
Thanks for the great offer for our members SatelliteAV.
Only 15 units remaining. Units will go on Ebay later this week
..... Going.... Going .... GONE!
Does Anyone Know of any 24/7 Analog Ku Channels ITC?
FTA installer Harrisburg PA
