Sorry I didn't realize you had 3 separate dishes. In that case I would keep the DPP33 switch.
--- thanks!!! ---
Make SEPARATE lines from the router to each hopper.--- a friend pass me this diagram, since he doesn't have any of the hoppers/joeys, i need to be sure this is correct ---
manteca said:--- another questions: can i transfer my 922 timers from my remote to the hopper? - can i connect more than one EHD to the hopper? ---
1. No.
2. I believe so.
Sent from my iPad 2 using Forum Runner
I have a $ question. I currently have 6 outlets being served:
- 2 722's
- 1 722k
I just signed a new 2 year deal maybe 6 months ago, to the get the 722k. Would it be cost effective for me to swap the 2 722's for a hopper + 3 joeys? I'm currently paying $32/month in receiver fees.
You would need 2 Hoppers and 4 Joeys. Which would be $35 per month in receiver fees and $299 upfront.
joshsquall said:I only want to replace the 722's (not the 722k), so I'd just need 1 Hopper and 3 Joeys. What's the price on that?
randykimj said:How many types of video and audio outputs do the Joey's have (DVI, component, composite, coax, optical audio). Is a signal fed to all outputs at the same time like the VIP receivers? Can they output different signals to the various outputs at the same time or do they all share a single feed? Does the Hopper itself have any outputs?
It works because it just dumps the entire transponder to the hard drive, then sorts out the data for the 4 major network channels upon playing it back.
Would be cool if the feature was not limited to the major networks - the ability to record all your shows, as many as you want at the same time, all using a single tuner. The obvious next step would be to use this method to cache a two-hour buffer of everything, not just one channel at a time. Think of it - being able to change channels and see an interesting show that was just ending, then backing up to watch the whole show, at anytime and not just prime time.If the recurring timer is one that is also being recorded by Prime Time Anytime then it will only use one tuner for both.
:Would be cool if the feature was not limited to the major networks - the ability to record all your shows, as many as you want at the same time, all using a single tuner. The obvious next step would be to use this method to cache a two-hour buffer of everything, not just one channel at a time. Think of it - being able to change channels and see an interesting show that was just ending, then backing up to watch the whole show, at anytime and not just prime time.
isaacmorseMI said:That is not possible as all of the cable channels are on many different transponders, PTAT works because Dish puts HD locals on a single transponder.
Neo2006 said:Please help ... I have a VIP722 (rental from Dish) I only use it for a single room. Is there any reason(s) to switch to Hopper or hold fast with what I have? Note I do have a 1080p / 3D capable new SONY TV.
Please advise & Thanks !!!!!!
bmallen1 said:So what's the best deal for existing customers thus far?
