Another (new) DISH salesperson...
I can probably count on one hand the # of people that actually care about this.
And besides, if you put the DVR in dual mode with the other room using the other tuner, what good does it do anyway?
Well maybe that's why it didn't work for you - I've NEVER tried to use an "FM mod" to do this. (I'm assuming you meant TV mod... )
But be that as it may, you CAN do it with ONE cable on D* as well - done it many a time on SWM systems & it works just fine, thank you!
Isn't this the same thing you just said above???
And if you do NOT have a phone or internet connection, you DO pay for it, at least on additional DVR's. Sorry, but many of my customers don't have either, so they are still getting a better deal w/2 separate DVR's, that have FOUR tuners for both rooms.
Yea, I'm well aware of this - I'm ALSO well aware that it STILL carries a separate DVR fee (again), just like all the other DVR's! Since VERY few of my clients get "everything", (before you mention AEP) this is still a deal breaker - again, for myself included. So, what is the point of this...D* is still a better deal then.
And AGAIN (for the umpteenth time!) - you ONLY get 2 tuners for BOTH rooms. Which means, of course, both rooms CANNOT watch & record 2 different things at once. You would not believe the number of E* subs I come across, that do NOT understand this - they really DO think you can do 2 things on EACH set - JUST like the 2 separate cable or D* DVR's they've had before, or seen at other homes. Nobody explained to them this (little) limitation BEFORE it was installed - but I'm SURE you explain it, right...
And BTW, what you said about E* only charging 1 HD fee is NOT entirely correct - on EACH additional HD box, they charge $2 MORE per month than D* does, so don't forget to add that in there as well.
And again, you get DOUBLE the tuners to work with. And again, for a mere $99, even a NEW sub in our area can get TWO dual-tuner HD DVR's from D*. Once I explain with the extra $5/month, they are actually getting TWO more tuners to record & watch, I can't tell you the last time a client didn't go for it. They are tickled to have 2 separate boxes with the 4 tuners & double the hard drive space to boot. (& please don't tell me about plugging in external HD's on E* - most "mortals" have NO clue how to screw around with this, nor have the desire)
1. You can do Picture in Picture with the Dish DVR.
3. You can feed multiple locations the signal from the DVR and do it with one cable and you don't need to use an FM mod to do it.
4. You can watch your recordings on any TV connected to the receiver (I know Direct is working on this but it's not main stream yet).
The biggest thing is Dishes dual tuner dual tv DVR's gives you choices. With Direct's you do get the automatic ability to watch and record, but thats all. You have more flexability with Dish.
By the way Don't forget that Dish has the 612 that is exactly the same setup as Direct's DVR's, a dual tuner DVR for one TV.
Dish stopped charging the phone line access fee on the first DVR. They also only charge one HD fee just like Direct. SO if you order a 2 tv install you only have the one box if you want.
With Direct it is automatic you will have 2 boxes with the extra $5.00 a month. Plus if you want DVR on both those tv's you have to spend an extra $100 or $200 to get the box.
