Hi,
I am currently a Dish customer withe the 522 receiver and I just installed a Channel Master 3671 antenna. I also purchased and installed the CM7777 preamp to boost my signal since I am over 40 miles away from the towers. I hooked up the preamp as per instructions and have a diplexer coming out of the preamp with one cable going to the main TV antenna input and the other cable going to a second diplexer. The second diplexer has the the TV2 output cable going into it and a second cable going to the second TV which is in the basement. This way the second TV gets the sattelite signal and OTA signal all on one cable. My problem is when I plug the CM7777 preamp in the satellite signal gets a bit fuzzy and degraded. When I unplug it the sattelite signal is good again. Is there a way to get rid of the interference when the CM7777 is plugged in? Did I hook this up the best way? Please help. Thanks.
