I have a new 625 receiver and a new DP quad LNB I’m trying to install. When I run the switch test, the Sat input 1 input always fails. The screen shows Status: Reception Verified, and Switch: None. (Sat Input 2 finds the DP quad)I reversed the two cables on the receiver and re-ran the test with same results. I tried different outputs of the LNB and the result was the same: Sat Input 1 always fails.
I called DishNetwork this morning and described the problem. The support tech told me I should utilize just one cable from the DP quad and run it through the separator that came with my receiver. I emphasized my LNB is not PLUS, it is just DP. He sad that’s OK, the minimum requirement is DP. I’m not so sure about that but he’s the professional and I’m the do-it-yourselfer. I have not tried that arrangement yet.
More background: I’m currently using a legacy twin LNB on a Dish 500 antenna feeding 2 legacy receivers. All new quad shield 3.0 GHz cable, no metal staples, and just one splice in the cable where the grounding block goes. The cable run is about 50-feet. Reception is excellent. This is the antenna and cabling I’m using when trying to bring up the 625.
Any thoughts what the problem may be?
