Is your dish up already? If not, be sure you have it on a perfectly plumb,vertical pole. You'll need to have an active transponder freq selected on your receiver to locate the satellite. The List, top of page here, will give you those freqs. 11720vertical, 11800 vertical are the ones with the most channels. Pick one of those to tune with, as they are pretty strong signals. dishpointer.com will give you the aiming coordinates, be sure to adjust the skew setting also, which will be in the 20-30 range depending on your longitude. Then its just a matter of slowly panning dish right and left in the gen direction of 123 while watching the signal meter. It takes time, move the dish small amounts at a time. Also, with those 2output lnbs you will need a 3x4multiswitch to get both polarities.
