Ok, here are some thoughts after using this set for awhile, and researching (with settings and experimentation) AVS mentioned issues. Im not debating if this is something I want to keep long term, or send back within my 30 day Amazon window...
I am seeing two things:
1) The blue blacks that were mentioned in the cnet article, which Im not sure if they would be fixed by calibration or not
2) My off angle viewing looks pinkish/washed on the edge of the opposing corner
Also realize, the reason I see this as a serious issue is because at my 9.5 ft distance, if I stare straight, Im looking at the right hand edge of the bezel. So my viewing angle is not anywhere near bad. This tells me this edge lit has some problems in it's design. Id guestimate that I see this 20% of the time, so it's quite common. Not a deal breaker, but it just does not look good. I'd also say it's about a 6" wide area, perfectly vertical that I see this issue with. And, once again, if I pause the video and move to my wife's position, the problem switches from one side tot he other. This tells me off angle veiwing issues. Also does not present itself with letterbox veiwing, so it must be something in the Micro Dimming limitiations with full screen content.
Another issue I have, AMP is broken. I read some of this aboutt he 2010's after I bought the set, and after some experimentation, I agree. With AMP set to Clear, everything works fine. With AMP in Standard, Smooth, or any combo of Blur/Judder in Custom, Amp stutters at times. Real annoying. Problem with clear is, the judder settings must be down low, because judder is there and to me, one reason for AMP is smoothing out judder.
And then there is the fact this is a $3k display...
