So far two reboots necessary to just use receiver. One Soft when I got home from work (1710) because of the blackscreen on current news recording. another around 1820 (pulled plug) because the system showed 6 recording as active.
1. Recordings are not firing off on schedule.
2. System will show in EPG that a recording is taking place, but the recording is not showing up in the DVR directory. Also the tuner can change channels without a warning.
3. Show will record and not "stop" when a new recording starts. The new recording with show up as a third concurrent recording.
exp
Show A 2100-2200 Tuner 1
Show B 2100-2200 Tuner 2
Show C 2200-2230 - Tuner 1
Show D 2200-2230 - Tuner 2
Show E 2235-2305 - Tuner 2
At 2210, Shows A,B,C were showing as recording. If I attempt to access show A, I get the black screen with the red dot with a slash. If I try to stop recording A, same thing. Shows B records as normal. Show C and D are recording their correct shows and I can access both live video or the recordings.
At 2239, Shows A, E are showing as active. I can tune the receiver via live on Tuner 1.
exp
