Does anyone know whether or not Dish would run Ethernet cable for a customer? I have weireless setup, but the signal is always really close to almost being nonexistent...
DISH Network technicians will not run Ethernet cables. They normally will install a Home Powerline Connection, using a SlingLink Turbo unit. http://www.dishnetwork.com/getconnected/get-connected/default.aspxDoes anyone know whether or not Dish would run Ethernet cable for a customer? I have weireless setup, but the signal is always really close to almost being nonexistent...
Claude Greiner said:They will use a sling powerline adaptor before they run staright Eithernet cable.
You would be surprised how small the bend radius is for fiber. Much less than that for RG6. IIRC, the guideline is 15x the cable diameter. That adds up to about 1-3/16" for 2mm cable.Much easier than fiber, with it's more critical turn radius.
Are you using something like B/G/N ? You might want to restrict to one band. I had signal issues upstairs until I switched to "G" only. I do prefer wired over wireless, but thought it might help in the meantime.
