Here is a pic of the area the higher frequency range runs. Lets hope it'll work for you guys with panels.
I will tell you the installers are not supposed to use it if its not marked, your experience may vary.
And that is only from node to hopper, joeys arent as picky.
Frankly, the reel I bought at Home Depot seemed to be of higher quality than what I bought at an electrical supply house.
That's where I got mine about 6 years ago. I'm checking mine when I get home from work. Now I'm nervous.
technically, the type of RG6 is not mentioned in any of the training documents that i've seen so far.This is something Dish needs to consider as they enter the age of Hopper/Joey. The big plus is using "existing" home wiring for whole-house DVR. It is not realistic to even suggest that non-rated RG6 be replaced instead of trying to use it. DIRT needs to pass along my suggestion for a release form in case existing wiring causes problems.
navychop said:I'll try to remember to also. We can compare notes.
It would take a long time to rerun that coax with higher quality stuff. Frankly, the reel I bought at Home Depot seemed to be of higher quality than what I bought at an electrical supply house.
Who would be releasing who from what with such a form?
This thread had me worried so I checked the RG6 quad-shield I installed throughout the house a few years ago - which also came from Home Depot. I was relieved when I checked the spool on the leftover cable and it read "sweep tested to 3GHz". navychop - hopefully you bought the same cable.
Mine is not quad shield. Makes for a bit more challenge with compression fittings, no?
Well, some is marked Perfect Vision 3GHz and some is only marked 797589 ft. ???
Pulling could be a tad difficult, as I drilled thru 2x4s and have little extra room for a barrel.
From the roof, thru the attic (which has since had a few inches of blown in insulation), down to the crawl space thru interior spaces around venting, across the crawl space, up thru an interior wall to the living room. Wall plates. Done right.
