Stopped by sadoun on the way home from work tonight to check out this receiver in person. I must say, this thing BS really fast!!! Took under 2 min to BS 97W. I did check about my autoscan questions and it looks like that you can deselect the sats in the sat list and then autoscan all of the sats left. When you go back to the sat list to enable the sat back, it holds all of the orig settings. So I wouldn't have to set the LNB and switch settings each time. This will work when I want to disable scaning my cband sat that is motorized but connected to my switch.
I'm about at 85% on purchasing this thing
One thing that I did notice is that you can't to a manual pid/channel entry. That would be nice to add in the event that it will not scan the channel in like some recievers have done in the past. Don't see why this couldn't be added in a future release or by pc once you can download the channel list to a PC.
One other observation that I wasn't able to verify: Does the receiver tell you if the TP or channel is DVB-S2? Was only able to test on 97w which doesn't have any S2 tps, but for you with this receiver does it indicate FEC, pilot or just simply "S2"?
One last thing: There is a section on the menu under "other" (forgot the 1st menu) that has "BER" on or off. Assuming this is "Bit error rate" but does anyone know what it does? I turned it on and off and scanned but couldn't see anything different.
Oh yeah...might not be a biggie to some people but I like that you can enable "beep" for setting up a sat. All my FTA receivers don't have this and I kinda missed this from my Dishnetwork/BEV dish setups back in the day. Wireless headphones on the roof made it easier to install a dish than lugging a TV up there.
Otherwise, this seems like a pretty good receiver. Nice OSD and looks like it also has some nice switch options as well.
For me personally, there are 3 things that would make this the ideal receiver that I believe should be possible via firmware (no evidence, just my personal view):
1) Allow both motorized and fixed dish solutions: Enough said!
2) Import/export channel lists: Let me save it, back it up, edit, and load back on
Eliminates the manual pid entry issue if it arises..
3) Network features!!! While not sure what it does now, make sure I can record to a remote drive. Don't need it to play DVDs or xvids, or youtube/hulu.....just LET ME STREAM FROM THIS BOX!!! If I can lock a Channel and stream the pids, then I don't care that it can't do 4.2.2 out of the box. Stream it to a device that can! If remote DVR storage is possible, then this should be too.
