Resume option missing on Joey
sourdough
43
Alaska
On the hopper when selecting a recording which has already been started (doesn't matter from where, joey, hopper, DA), one of the menu options is "Resume". This option will render an option screen if there are resume points from other devices allowing you to select which to use.
The Joey has identical functionality, except the "resume" menu option never shows up. You can access it by hitting 'play' on the remote when a recording is highlighted. There is no UI element indicating that (not intuitive). I assume this is a bug/oversight in the current Joey software (S298).
My Joey with same sw has no such problem. Have you tried resetting?
How are your events sorted? Custom folders or folder by title?
It is normally on custom folders. I just checked with folder by title and the resume option does appear in that mode.
Also checked the hopper (HWS S315) problem appears there too. Don't normally use the folders on the Hopper so never noticed it there.
So another bug with folders I suppose.
Dish Anywhere App!!
Did we lose the Chinese television channel CCTV?
