Many people do two or three lnbs on one or more stationary dishes. Connect everything to your receiver with a 4 or 8 port diseqc switch (or multiswitches and diseqcs if feeding more than one receiver). Channel changes on those lnbs are instant as you don't need to wait for the dish to move. It can be done on both C and Ku dishes. Check out these threads for ideas:Multiple LNB's, would I somehow need to interface a switch in there somehow? There's receivers that rotate the dish to the bird you want, not sure how it works otherwise.
Sorry, picked up on Thursdays. If'n I run across another I'll keep in mindIf the boxes still sit there, you can save your stickers. I'll take 'em.![]()
Focal length won't be uniform across the whole dish. This thread is a very informative read.Multiple LNB setups look like a lot of fun. I see the mounts for multiple LNBs on offset dishes being straight rather than being bowed, I figured the focal length wouldn't be uniform going across like that. Or does that only work on certain dishes? Would I be able to use the parabola calculator to determine whether the LNB mount would need to be bowed or not?
No. it will only calculate the point for the center LNBF. Those mounted off to the side is pretty much trial and error for the most part. LNBF's mounted to the west (east) of the center will see east (west) of the centered LNBF.Would I be able to use the parabola calculator to determine whether the LNB mount would need to be bowed or not?
