Can I replace a dish pro lnb on a 500 dish for 110 and 119, with a dish pro plus for 110 and 119? I still have a 34 switch. thanks for any help
It would work temporarily but would ultimately fail. DPP lnbf's have a built in switch and thus should not be connected to another switch. You should either replace the DP Twin with another DP Twin or 2 DP Duals. If you wanna use the DPP Twin you should remove the DP34
yes - the DPP will work with both a DP34 and a DP44
NO - it will not last long it WILL fail (you're running a switch into a switch - any good installer knows this.
Do yourself a favor and replace the DP Twin with another DP Twin or 2 DP Singles/Duals, or use your DPP Twin and remove the DP34.
Do it right or why do it at all
Those LNB's get hooked up to 44 switches all the time, when a customer needs more than three outs. The on-LNB switch is disabled when a 44 switch is present. If you want me to believe that it will fail, point me to the dish technical memo on that.
I have a DPP LNB running into a 44 switch and have for the past 5 years. Are you telling me I am 'lucky'... Yeah, right.
I was able to use the lnb I had which was dish pro and ran it into the 44 switch to pick up 110,now I have EA and 110. I had to use the old dp34 and my 522 to locate 110 first, then plugged it into the 44 and did a check switch and it was there. I was unable to locate any sats going directly into the 44, but as soon as I tried it on the old stuff I found it in about 30 seconds. I can now get my locals in SD just in case 61.5 explodes
