I have a Dish Hopper with Sling; 1 Super Joey, and 2 (regular) Joeys. If it matters (probably not) we have two dishes/receivers on the system. It is time to replace the TVs attached to these tuners (past time, in some cases
The Hopper is in the master BR with a smallish Vizio LCD that now has some pretty impressive screen burn. The other two Joeys are each in a guest BR with older LCD TVs that were arguably inadequate (very small) from the get go. The LR TV is an older 44" RCA on the Super Joey that requires its own independent remote (!). I figure I can fit a 50 -55" in the LR. That is on a corner cabinet; I am constrained by that arrangement from going larger (angle of viewing is also of some concern there). The BRs would probably be adequately served by the next smaller size class TVs, but since those are on dresser-top mounts, I have more flexibility. I did already do some research on general TV recommendations for 2021: the CNET review guy likes TCL 6s, 5s, & 4s for value (I am value oriented myself
with some VIsios and Samsungs falling in just behind the TCLs. All of which is well and good, but I'm not sure how well his criteria (mostly subjective/unstated) fit my needs (I'm also unsure if there is currently enough variety in available features that this makes any difference). First, any feature that doesn't enhance Dish or DIsh/DVR viewing, or actually impairs some DIsh function, is unneeded/unwanted. My internet bandwidth here is constrained (768k down, half that up) to the point that Netflix/Roku, et al, is not a consideration. Neither do I have any interest in voice operation, whether local, or of the Alexa (connected) type. In fact, I insist that I be able to permanently disable (or otherwise render nonfunctional) any Alexa-class interactive component due to privacy concerns. I'm guessing that I should probably jump on my faithful nag Rocinante and go joust some windmills now
So, did anyone stay awake enough through this missive to point me in a fruitful direction for TV selection (or to point out to me just how f****d I really am on this quest)? Thanks in advance for your insights.
