Remove Joey from Account?
jontheophilus
18
Indianapolis, IN
I tried searching for this, but most threads seem related to canceling everything. Let's say I setup myself with 2 Hoppers and 2 Joey, can I remove one the of Joeys from my account and send it back to Dish? Say in the situation I find we can't justify the $7/month for a TV that's never watched.
Thanks.
Sorry to dig up an old thread, but does the the outlet need some sort of termination or just unplug and return the Joey.
You can just send it back. If a termination was required they would need to send a truck, they don't assume you know anything about how to terminate or even what a terminator looks like.
Reactions: HipKat and Tampa8
Don't we all know though?
Are you saying that leaving that coax unterminated won't have a negative impact on the MOCA or signal quality to the hopper3 or superjoey? I've always wanted things done correctly. I'm guessing that if they send a truck, the tech would replace the splitter or whatever it's called these days, or screw some kind of terminating cap on the coax.
If you want to terminate it, go for it. It won't hurt anything
If you call Dish and give them the Joey receiver ID, they will send you a pre-paid UPS box with sticker so you can send it back to them.
You are correct to electrically terminate the old cable as it will mess with the signal degradation and impedance of the 75 ohm coax.
There are two ways to do this, either at the old Joey end in which case you would just need a barrel connector and a 75ohm terminating plug.
The terminators are dirt cheap, you used to be able to get them at Radio Shack but I still think Home Depot or Lowes might have them.
But either way, you can get a pack of 10 for about $5 from Amazon Prime.
Amazon product ASIN B000AAN76Y
I you have an loose or unterminated coax lines, you really need to put a 75ohm load on it so it doesn't 'leak' out signal.
So if you can trace the cable back to the block where it comes from, simply unscrew it and screw in the terminating plug.
If you don't want that hassle, you can just get some coax barrel connectors (I know HD has those). Screw one end into the coax and screw the terminating plug into the other and you are done.
If you are lazy and just want to get it all delivered, here is the link from Amazon for the barrel connectors (you may even have some laying around).
There are tons of them on Amazon for just a cheap, just search on 'cable barrel connector' But if you them make sure you get the ones with the BLUE center insulator as Dish also supplies a higher power over the MOCA connection.
Here is an example of some. If you go to HD, then don't get the ones that are white of clear in the center, make sure they are the blue ones.
Amazon product ASIN B01E6ZENCK
These are 10 for 8 bucks but they also have packs of 5 for 5. Personally it's good to have some laying around in case you need to extend and existing coax cable.
I have no idea what you're talking about here. Removing a Joey and not terminating is not a big deal, however, if you're talking about terminating a "live" cable from the LNBF at the ground block, that is a HUGE no-no
Thanks. I've already called and the return process is in the works. I also asked the the service rep and was told nothing needs to be done at my house. I've learned to never trust what someone in a sales/service position says. That's why I asked here first. You've confirmed what I suspected and provided information to substantiate your advice. The time, effort and information provided in your reply is greatly appreciated.
I think he means terminating the signal from the node or the newer switch that goes to the potential joeys you wouldn't need on your system.
Reactions: TheKrell
How long old receivers supported.
Local HD channel issue
