Iceberg said:couldn't you use like the "tape out" jacks to the VCR? Will that work??
Yep... unless you happen to have a camcorder on hand and can figure out a way to either just hit record on it about 4 feet in front of the tv... It won't look great, but at least it'll record. I got my ancient camcorder about a year ago at a garage sale for 5.00.You will need an output from your Yamaha to the VCR. Regular rca plugs should work. If the Yamaha doesn't have an output, you're s*** out of luck.
kelleyga said:Hi Havenx, this is what I did, but did not work
1- RED,YELLOW, WHITE from Pansat to Yamaha Reciever TV/DSS INPUT
2- RED,YELLOW,WHITE from Yamaha Reciever VCR OUT to VCR Unit INPUT
3- RED, YELLOW,WHITE from VCR Unit Output to Zenit TV INPUT
4- Set the VCR to AUX channel
5- Press Record
The VCR recorded but NO volume. Any thing you think I am doing wrong????
Also what do you mean when you say: be using it as an A/V swith or it won't work ??????
hmmmmmmm Well his reciever should still ouput sound on the headphone output. Headphone output to vcr sound inputz4ccamaro said:Some receivers will not output digital signals through the analog out jacks if the only signal coming in is digital (Pansat) They need an analog audio signal coming in also. The manual for my Sony receiver even says so (in very small print)
