Recording on DirecTV's 4K Channel a Possibility
maestro7
250
54
Just in from Phillip Swann...
http://tvanswerman.com/2016/03/16/update-can-you-record-directvs-4k-channel/
No actual details have been released yet. However, as previously noted, if uncompressed 4K equates to 500GB per one hour of content, then even at a compressed rate it doesn't seem (on the face of it) to be worth it to record 4K at this point, as you'll have to have a significant portion of your DVR reserved for one show, and maybe not even an entire show.
We'll see.
Yes, you will be able to record it - using a reverse Band LNB-But only able to play it in 4K is viewing it through WHole home - From a C61K attached to a 4K TV.
Starting in April 2016
I have 11 hours HD and about 5 hours 40 minutes of 4K recorded on the HR54 internal drive and still have 87% free.
Wow. That's some serious 4K compression.
Any idea what the ratio is for that kind of compression? Almost sounds like a greater than 80% reduction, assuming 500GB/hour uncompressed. I also can't imagine they're putting in more than a couple of terabyte drive in the device.
I recorded some of the Golf Test and it recorded fine.
I was watching channel 104 last night and they had an interview with Joe Jonas on and the picture looked great but still had a lot of stutter. I hope they fix the C61K soon so it displays 60 fps instead of 24.
Reactions: Hideftv
Is DirecTV going to update their UI ?
Youtube Gone from DIRECTV
