Hello,
Does SWM artificially inflate signal readings due to it being a powered system? I had my DirecTV installed at my apartment late last year, and the signal did not go out once during the winter even with the heavy snow and ice. However, storm season is starting, and the signal is lost from about 5 minutes before a storm starts (a little earlier than when you start to see lightning overhead) until after the storm has passed over. This also happens with moderately heavy rain and no lightning. This did not happen with the unpowered 1-bird setup I had years ago in St. Louis--back then the signal would only drop out in the heaviest of storms.
My signal readouts are all high-90s, with a few 100s. Currently I'm using 3 tuners from my SWM-8: two for an HR21, and one for a H21.
Is there anything that could be wrong with this setup to cause this? The location of my living room means I cannot pull in the local stations OTA, and the signal dropping out so early means I can't get an accurate assessment of the storm since I usually watch previously recorded programs in the evening.
