GregH said:I have a Samsung 1080 TV and a 942. To get a 622 is going to cost me $300. Am I likely to see a significant improvement in PQ with a 622? What other advantages are there in switching to the 622?
samgovol said:When you use the OTA option, the antenna goes into the receiver correct? Once it is in the receiver, does the program guide recognize my locals?
You have to go in and scan for them and it will find the ones with a signal.
Also, using the OTA option, can you use the DVR function with the channels that come in OTA? (i.e. record local channels on the hard drive?)
Clarification: if you subscribe to the SD locals package for your area, you will get guide data for some or most of the digital locals. In most cases channel xx-1 will be the OTA digital equivalent of xx-0 which is the analog local from the satellite. Both have the same guide information regardless of whether they are always showing the same content. Other OTA channels such as xx-2 will simply be listed as "Digital Service" so you would have to setup manual timers for those.samgovol said:When you use the OTA option, the antenna goes into the receiver correct? Once it is in the receiver, does the program guide recognize my locals? Also, using the OTA option, can you use the DVR function with the channels that come in OTA? (i.e. record local channels on the hard drive?)
Just for clarification, you can only record DIGITAL channels.SatelliteGAL said:Yes, you can record your OTA channels.
lakebum431 said:Yep, very cool device. Feel free to ask anything else, there are tons of people here that know more than me and are very willing to help.
nlk10010 said:I know about the HDTV setup option but that's for OTA, which I don't have. Since I HAVE come across threads in which reference is made to setting the output resolution of the 622 my question, again, is: So, WHERE IS IT? (ducking)
Jim S. said:I thought that the "HDTV Setup" screen was the output setup screen. Mind you, I'm still trying to figure out (check the rest of the threads for mine) what the "analog input" setting is for. I can't make sense of it.
 ) but IN NO CASE has anything to do with what happens to the signals you receive on the 622's satellite inputs.
 ) but IN NO CASE has anything to do with what happens to the signals you receive on the 622's satellite inputs.HDTV setup screen is for ALL sources and for the analog output by the Agile Modulator. MENU-6-8 I believe (I'm not at home right now).nlk10010 said:Well, on either this or another forum I was told explicitly that the HDTV SETUP option is JUST for OTA sources and useless if you aren't receiving OTA signals. The ANALOG INPUT setting then has something to do with the sequence/format in which you're getting the channels (I think) but IN NO CASE has anything to do with what happens to the signals you receive on the 622's satellite inputs.
Go figure.
=NLK=
Jim5506 said:HDTV setup screen is for ALL sources and for the analog output by the Agile Modulator. MENU-6-8 I believe (I'm not at home right now).
