I've been playing around for a coupla weeks with my 3ABN dish sitting on sawhorses and coax snaking out a window with some rags keeping the cold air out (mostly). One thing's for sure - if you weight down the plywood the dish is bolted to with some big rocks the dish is less likely to blow over! (found that out the hard way). Anyway I'm getting to the point where I'm thinking of a motorized setup but have some issues to overcome that maybe some of the more experienced hands can help me with.
First off is where to situate the dish. Easiest would be the roof of the house. Sitting up there the other day with a compass and my soda straw inclinometer I figure I can see way out to the Atlantic down to about 20 degrees elevation to the east but only to about 107W to the west because of the dang oak tree across the street. There is a spot on the ground next to the house where I can see G10 through a gap in the trees. So one option would be a motorized to see 50 something W to 107W plus a fixed dish for G10.
Q#1 If I went this route would I be missing very much FTA-wise between 107W and 123W?
The other option is to put the motor on the roof of the garage, which is detached and sits maybe sixty feet back from the house. Since the garage is a lot further back from the dang oak tree I can see over it and would be able to see everything on the arc higher than 20 degrees elevation both to the east and west.
The issue here is the long cable run, probably a good 110 feet of cable to the house and another 25 feet in the house for a total run of 135 feet.
Q#2 Is 135 feet too long for motor control?
Q#3 If I have more than one LNB on the motorized dish am I better off using 22Khz switches or diseqc switches at the end of that 135 foot cable run?
I found an article about burying coax here:
Coaxial Coax Cable and moisture and burying
So I'm thinking a belt-and-suspenders approach might be to use RG-11 coax rated for direct burial, but run it through PVC instead of directly in the ground. RG-11 because less line loss and better chance of getting enough current out there to turn the motor (14 gauge for RG-11 as opposed to 18 gauge for RG-6). Direct burial as opposed to regular RG-11 because it will last longer subjected to moisture outside. Run the coax through PVC to provide more protection to the coax both from salts in the ground and from an errant shovel when I'm out there gardening.
Q#4 What do y'all think about my comments about burying coax?
Q#5 All things considered am I better off on the house roof or the garage roof?
