Trying to disable Primetime Anytime, but every time I do it just goes back to enabled after I save it.
Any ideas?
Any ideas?
Any ideas?
welcome to the club... http://www.satelliteguys.us/hopper-zone/280105-ptat-bugs-problems-dislikes-18.html#post2831506Trying to disable Primetime Anytime, but every time I do it just goes back to enabled after I save it.
Any ideas?
We are former TiVo users and only quit because our local cable company is not required (or weren't at the time anyway) to have CableCards, making it impossible to use the newer TiVos once the cable company got rid of the analog channels (which they did before they were required to).
: to SatGuys!Whole-home DVR differs from existing Duo DVRs by making recordings available to more than 2 independent TVs, and each additional TV can be get an HD output from its own Joey which accesses the Hopper. Rather than having a TV1 and TV2 each getting assigned a tuner, the Hopper has 3 tuners, and each user or timer that needs one dynamically gets assigned whichever one is available. If all tuners are taken, the viewer has the option to join what another is watching or to play a recording. In addition, a 2 Hopper household can have up to 4 Joeys, with all users expected to have access to the 6 tuners and recordings on both Hoppers (future feature, waiting for details and demo).
Cable companies have never been required to get rid of analog channels. Most cable companies still have at least a few.
Oh, and: to SatGuys!
4) Will the Hopper STOP recording every episode of The Colbert Report and Simpsons even though I have it set to only record new episodes? Gah! (I realize this is probably more of a guide issue, since I realize that the extra episodes it records usually have generic episode information: "The Colbert Report is satire political show. 2005." But still, I'm tired of skipping all of these episodes individually...
Most cable companies got rid of analog, because they can cram more down the pipe when it's bit reduced. Analog channels hog up the cable pipeline.
A side benefit to the cable companies is that it requires a convertor to view in each room. Although, Comcast gave out free ones (up to 3 per home), when they reclaimed analog bandwidth in my area.
And perhaps "required to" was the wrong word. Our small, local cable company does not offer any analog channels. They got rid of them in one fell swoop years ago. I guess it would have been more correct to say they switched to all digital before they needed to. In my brain I twisted that to "they were required to get rid of analog." My apologies for my ignorance.I know WHY most cable companies got rid of most analog channels. That wasn't what I said. I said cable companies were never REQUIRED to, which is what Cruciatus was claiming.
kwindrem said:You can use a USB hub if you run short o USB ports. Others have insisted powered hubs were necessary but passive worked fine for me, just not all models. I had troubles with the first hub I tried but a different model worked OK. Both were the really cheep ones you find on eBay.
--- the remote control buttons glows in the dark or are just white in color? ---
Not really. The hub draws very little power from the USB port. I'm not suggesting you power one or more USB drives from the USB port! If the drives and other devices plugged into the receiver's USB ports or a hub are powered locally, there's no real advantage to a powered hub.a non powered hub might work but you are taxing the power supply on the Hopper.
Second, my wife was on the TV with a Hopper watching a show live on HGTV at the same time it was being recorded. At the same time, a game was being recorded on Fox Soccer Channel. PTAT is disabled on this Hopper. When I tried to watch something on the Joey TV paired to that Hopper, it indicated the tuners were all being used. It showed one HGTV show "Recording", the same HGTV show "Watching", and a soccer game as "Watching & Recording". The time remaining on the HGTV listings was the same, and changed at the same time, so I'm sure she was watching it live as it was being recorded. Is the Hopper really using 2 tuners for the 2 HGTV events, or is something just set up wrong?
