Here's my present setup:
Dish 500 with Legacy Twin picking up 110 & 119
Dish 300 with Legacy Dual picking up 61.5
SW21 switches combining one output from D500 with one output from D300.
Two RG-6 feeds coming into the house, going into a 942.
Now I would like to reconnect my old 4900 to drive a 2nd TV. I want to retain the ability to record off of Tuner 2 on the 942 to my primary HDTV.
The way I read things is that I would need to do something like:
Replace all LNBs with Dish Pro units.
Connect both runs from the D500 DP to a DP34 to provide 110 & 119
Connect a run from the D300 DP to the DP34
Then connect two outputs from the DP34 to the 942
Connect one output from the DP34 to the 4900.
Correct?
If so, then I guess I would need a DP Adapter for the 4900.
Correct?
