I want to receive programs on two Dish 322 dual tuner STBs from only one satellite (118.7) using a 500+ dish and the existing single RG-6 cabling system in the house, together with Comcast. If any one could enlight me on answers to the following questions, that will be greatly appreciated.
1. Given that I want all four tuners to receive programs from the same satellite, can I skip the switch (DP34) at all by simply using a DishPro splitter to distribute the Dish signal to the tuners? Can diplexers be added in between the 500+ and the splitter?
2. If I have to have a DP34 installed, can it be installed near the receivers after two diplexers? Basically I plan to use a single cable (110ft) from 500+ to diplexer, mix signal with Comcast, go through a single RG-6 cable (30ft) to inside the house, use another diplexer to seperate the dish signal and Comcast signal, and use a single RG-6 cable (30ft) to pass the dish signal to a DP34, which then connects to the four tuners with four 1ft cables.
