Hey guys, I have been making phone calls, made a few drives through the countryside yesterday talking with some folks, joined freecycle, and then sat back and waited for the phone to ring.
God has surely blessed my scrounging, as this is the first of the many finds I will end up with.
I was referred to an old Primestar dealer yesterday by a friend in the business, called him to make inquiries. He said he had some stuff in the loft of his garage, and would have to look at it and call me back. The following is all he had left, and I cleaned it out.
2 - 84e 40x30" Primestar dishes, brand new and still in the box with plastic wrapper on them and instruction manual. BTW the LNB's have two outputs, one for vertical and one for horizontal, and no identification on it other than a simple number 989080731.
6 - Channel Master non-penetrating pole mounts 36x36" with 26.5" upright still in the box.
2 - 72 inch ground poles, brand new.
Here are a couple of pics:
I gave him $60.00 for all of it. $10.00 each for the 2 dishes, and $5.00 each for everything else. I feel so fortunate to make this great find.
This will make everyone sick. He told me that about a year after Primestar went out of business, he had tried to sell some of the big round 41x44" metal dishes, and ended up hauling off a 2-ton truck load of them to the dump just to make room in his garage. This was all he had left.
I do have a couple of questions:
1. If you look closely at the picture of the dish there is a little piece of gray plastic on top of the plastic bag. It is a piece of the visor on the feed horn that has broken off sometime during the long time of storage, movement around, etc. That piece was still in the box, but the other one is broken too at the same spot, and I guess that piece fell out of the box at one time or the other, because it is missing.
Will that little portion of the visor affect the signal caught by the dish?
2. The next two are about the mount.
The mast on the mount is 26.5" tall. Will that be high enough for me to motorize this dish and it not hit the roof, or blocks when it is all the way over?
3. The current mast on the mount is 1/16" steel, whereas the ground poles are 1/8" steel. Should I replace the current mast with a piece of the heavier pole and move it up to maybe 36"?
4. Will one section of this mount hold this dish at 36" with an SG2100 motor on it?
If not, I can bolt two of them together into one and adapt the mast to both. making it 6x3'.
I have to go look at a metal dish tomorrow afternoon that is supposed to be over 40" round. We'll see when I get there. The guy wants $50.00 for it, and again we'll have to see how much I think it is worth to me.
If you can answer any of the questions above, I would appreciate it very much. Am very close to putting up a dish now, just have to order a motor and a UHF remote control, run some coax, and I will be in business.
Thanks, Fred
