If I had a 622/722 in the Living Room and if I wanted to hook it to two TV's I know I can use the TV2 output. The problem is, the second output doesn't do HD and I have a 52" LCD in the Living Room and a 46" in the bedroom. What I want to be able to do is watch shows that are recorded on the one DVR in both rooms in HD.
So, I have a few questions:
1) Can you send the HDMI output to one TV and the Component ouput to another TV? What I mean is, are all the output's active at the same time? I know if that were the case, you would have to watch the same show on both TV's which is fine.
2) If that is the case, do component cables do a good job of displaying an HD signal? Does the screen size matter? For instance, would I be better off sending the HDMI to the bigger TV and the component to the smaller set? Or would that not make too big of a diference? The audio isn't a big concern here since I don't have surround sound anyway. All I care about is the picture quality.
3) If all this were possible, would I even be able to use my remote that controls the TV1 output of the box from room to room? Or would I have to use the RF remote to control the TV1 output? And can you even use that RF remote to control the TV1 output or is that solely for the TV2 output?
Thanks in advance for any help!
